24 | Backend / Core | Bug Report | Very Low | High | DDE Read Errors incorrect data | Assigned | |
Task Description
bad data reading in: temperature coolant, Rail Pressure, Injection Volume. Test with engine running, 770 RPM, coolant 86 ° C, etc. Log:
0100 - air mass meter
Count : 40
Error currently present
Error not self-clearing
Error on first occurrence with environment block 1 debounced saved.
Error (for MIL) currently debounced entered.
Error number : 1
Engine RPM : 799.2 1/min
Engine coolant temperature : -11.7 °C
Injection volume : 0.0 mm^3
Rail pressure : 0.0 bar
44 | Backend / Core | Bug Report | Very Low | High | after car scan I get only DDE module line no others | Unconfirmed | |
Task Description
First time I use Toaf on my RV75 year 2004 I got it running and communicate but car scan returns DDE/DME module info only no other one in the list when clicking each modules either it says module not found/com error or shows the scroll bar and then displays a new page but info is missing. some wierd characters appear in some fields in low portion of the page
17 | Backend / Core | Bug Report | Very Low | Medium | BCU Control | Closed | |
Task Description
Unlock doors in all options and rear windows rigth and left open/close errors. That’s not working //mega.nz/file/1EYmmJhS#Z5IWgHhr70eGZvk8hwq_e00MqSJoSn_o302WUmB_JH4
18 | Backend / Core | Feature Request | Very Low | Medium | Translate to Spanish | Unconfirmed | |
Task Description
no task description |
20 | Backend / Core | Bug Report | Very Low | Medium | DDE module control option not work | Closed | |
Task Description
//mega.nz/file/Rd52DCrQ#rqtFmDEyPQ0dP-FEn_l4UMx2XfkJIk_8BbczzC5MiUE
21 | Backend / Core | Bug Report | Very Low | Medium | Restore BCU backup error | Closed | |
Task Description
Error: driver window does not close when restoring BCU from backup. returned to normal when restoring backup with toaf for windows
25 | Backend / Core | Bug Report | Very Low | Medium | ABS Live data | Closed | |
Task Description
ABS live data log and live data chart not work. Always shows the value “0”
2 | Backend / Core | Feature Request | Medium | Low | Module support : Cruise Control V6 | Closed | |
Task Description
Add support to : Cruise Control module
3 | Backend / Core | Feature Request | Medium | Low | Module support : MEMS3 | Closed | |
Task Description
Add support : MEMS3 ECU - 1.8/1.8T Engine
4 | Backend / Core | Feature Request | Medium | Low | Module support : EMS2000 | Closed | |
Task Description
Add module : EMS2000 ECU - 2.0/2.5 V6 Engine.
5 | Backend / Core | Feature Request | Medium | Low | Module support : RS | Closed | |
Task Description
Add module : RS - Rain sensor ECU
6 | Backend / Core | Feature Request | Medium | Low | Module support : JATCO | Closed | |
Task Description
Add module : JATCO ECU - automatic gearbox.
7 | Backend / Core | Feature Request | Medium | Low | Module support : SMAC | Closed | |
Task Description
Add module : SMAC ECU - Seat memory and control
8 | Backend / Core | Feature Request | Medium | Low | Module support : SHD | Closed | |
Task Description
Add module : SHD - sunroof
9 | Backend / Core | Feature Request | Medium | Low | Module support : ATC | Closed | |
Task Description
Add module : ATC ECU - Automatic climate control
10 | Backend / Core | Feature Request | Medium | Low | Module support : WEBASTO | New | |
Task Description
Add module : WEBASTO - fuel buning heater.
11 | Backend / Core | Feature Request | Low | Low | Feature : fast actions | New | |
Task Description
Add feature : fast actions, like boot open, police headlight activation as button on app main window.
12 | Backend / Core | Feature Request | Medium | Low | Feature : parameters monitoring | New | |
Task Description
Add feature : parameters monitoring like engine temperature, and show notification/alarm when value reach limit
13 | Backend / Core | Feature Request | Medium | Low | Module support : PDC | Closed | |
Task Description
Add module : PDC - park distance control.
14 | Backend / Core | Feature Request | Medium | Low | Translation : PL | New | |
Task Description
Add translation : polish Language
15 | Backend / Core | Feature Request | Medium | Low | Module support : BM | New | |
Task Description
Module support : BM - board monitor
16 | Backend / Core | Feature Request | Medium | Low | Module support : CDC | New | |
Task Description
Module support : CDC - CD Changer.
19 | Backend / Core | Feature Request | Medium | Low | ECU Backup | Closed | |
Task Description
Backup for modules stored in network.
22 | Backend / Core | Bug Report | Very Low | Low | DDE Live data/ Start log error | Closed | |
Task Description
DDE Live data: error when selecting multiple options. Many options are repeated or similar so the app closes unexpectedly, there should be a warning sign before generating the crash
23 | Backend / Core | Bug Report | Very Low | Low | DDE Live data/ Start log error | Closed | |
Task Description
26 | Backend / Core | Bug Report | Medium | Low | WIFI Interface | New | |
Task Description
Wifi interface for Toaf Mobile
27 | Backend / Core | Bug Report | Medium | Low | DDE injectors Live data not working | Closed | |
Task Description
Live data for DDE injectors not working property
28 | Backend / Core | Bug Report | Very Low | Low | Just want to say Hi! | Unconfirmed | |
Task Description
eyeglasses singapore,eyeglass frames,square eyeglass framesAt HP-eyglasses, we understand that eyewear isn't just an accessory; it's an extension of your personality. Our frames are designed not just to complement your features but to celebrate the distinctive beauty of Asian heritage. With an unswerving dedication to excellence, we proudly extend our bespoke prescription eyeglass fitting service, honed over a decade of experience. Your visual clarity is our priority, and we tailor prescription lenses to harmonize with your individual needs.Elevate your eyewear experience to an art form. Discover the intersection of trendsetting style and impeccable functionality with our exquisite eyeglass frames. Your journey to eyewear excellence begins here.
29 | Backend / Core | Bug Report | Very Low | Low | Im glad I now signed up | Unconfirmed | |
Task Description
glass bottle manufacturerDANYANG ENCHENG GLASS CO.,LTD. ,is the largest glass bottle manufacturing plant in Danyang, Jiangsu province, can design and produce any glass containers/bottle from 2ml - 4,000ml in capacity and provide the further processing treatment on . We own three workshops and the daily productivity is 180 tons (200,000pcs of 500ml bottles and 600,000 250ml bottles repectively). Our products consist of various wine bottles, juice bottles, water cups, beer mug, candle jars, food jars for honey, jam, picked food, salad and spice as well as Perfume bottles , diffuser lamp , liquid soap bottles and cosmetic jars. Besides, our plant can also provide the further processing treatment on our prouducts including coating, frosting, printing and labeling. We have both tin/aluminum cap workshop and plastic workshop for our bottle products.
30 | Backend / Core | Bug Report | Very Low | Low | Just wanted to say Hi. | Unconfirmed | |
Task Description
https://rpg999auto.com/ RPG999
31 | Backend / Core | Bug Report | Very Low | Low | Im happy I finally registered | Unconfirmed | |
Task Description
glass bottle manufacturerDANYANG ENCHENG GLASS CO., LTD. ,is the largest glass bottle manufacturing plant in Danyang, Jiangsu province, can design and produce any glass containers/bottle from 2ml - 4,000ml in capacity and provide the further processing treatment on . We own three workshops and the daily productivity is 180 tons (200,000pcs of 500ml bottles and 600,000 250ml bottles repectively). Our products consist of various wine bottles, juice bottles, water cups, beer mug, candle jars, food jars for honey, jam, picked food, salad and spice as well as Perfume bottles , diffuser lamp , liquid soap bottles and cosmetic jars. Besides, our plant can also provide the further processing treatment on our prouducts including coating, frosting, printing and labeling. We have both tin/aluminum cap workshop and plastic workshop for our bottle products.
32 | Backend / Core | Bug Report | Very Low | Low | Just want to say Hello. | Unconfirmed | |
Task Description
MicroBulk Storage SystemsDSW is one of the leading manufacturers and exporters of high-pressure gascylinders and gas tanks with industry-leading manufacturing ability that deliversunrivaled gas cylinder stability. DSW enjoys a reputation as an industry leader inquality and performance, which helps us sell industry gas tanks and Cryogenic Tanksworldwide.
33 | Backend / Core | Bug Report | Very Low | Low | Plumbing Edwardsville IL Experts | Focused Plumbing | Unconfirmed | |
Task Description
Focused Plumbing 519 W Lake Dr Edwardsville IL 62025 (618) 418-3102 Plumbing
34 | Backend / Core | Bug Report | Very Low | Low | Im glad I now registered | Unconfirmed | |
Task Description
Focus Lawns 1659 N Church Belleville IL 62221 (618) 400-0930 lawn care belleville il
35 | Backend / Core | Bug Report | Very Low | Low | IDSeal | Unconfirmed | |
Task Description
IDSeal.net 2661 N Illinois St Suite 353A Belleville, IL 62226 (618) 312-7605 idshield
36 | Backend / Core | Bug Report | Very Low | Low | I am the new guy | Unconfirmed | |
Task Description
glufosinate herbicide label,glufosinate label,glufosinate ammonium label,glufosinate ammonium toxicityIn the world of contemporary agriculture, the need for high-efficiency, low-toxicity, and eco-friendly herbicides has never been higher. Jiangsu Agro Farm Chemical Co., Ltd. stands at the leading edge of this agricultural revolution, devoted to the research study, advancement, production, and sales of cutting-edge herbicides.
37 | Backend / Core | Bug Report | Very Low | Low | Im glad I finally registered | Unconfirmed | |
Task Description
obviously like your web-site however you have to check the spelling on quite a few of your posts. A number of them are rife with spelling issues and I in finding it very troublesome to inform the reality however I'll certainly come back again. Meriah 4d
38 | Backend / Core | Bug Report | Very Low | Low | Im happy I finally signed up | Unconfirmed | |
Task Description
Uncover the universe of environmentally friendly energy in the bevverage industry. Comprehend how precisely forefront companies are leveraging hydro energy for craft preferred beveraes whilst reducing thhe carbon footprint. Keepp enlightened via our detailed write-ups, real-world examples,and insightful resources. Be a member oof our revolution toward a more eco-consciousplanet with our platform. GreenBeverageProduction
39 | Backend / Core | Bug Report | Very Low | Low | Im happy I finally registered | Unconfirmed | |
Task Description
Liquid nitrogen dewar,cryogenic nitrogen dewars,cryogenic nitrogen tank,cro storage dewars,nitrogen dewar flask,cryogenic dewar supplier,china liquid nitrogen dewar,cryo dewar manufacturerDSW is one of the leading manufacturers and exporters ofhigh-pressure gas cylinders, cryogenic tanks, and gas tankswith industry-leading manufacturing ability that deliversunrivaled gas cylinder stability. DSW enjoys a reputation asan industry leader in quality and performance, which helpsus to sell industry gas tanks and Cryogenic Tanks all over theworld.
40 | Backend / Core | Bug Report | Very Low | Low | I am the new guy | Unconfirmed | |
Task Description
Worman Law LLC 222 S Meramec Avee Suite 203 St. Louis MO 63105 (314) 695-9529 dog bite lawyer st louis
41 | Backend / Core | Bug Report | Very Low | Low | Im glad I now signed up | Unconfirmed | |
Task Description
Just wish to say your article is as astounding. The clearness in your post is simply spectacular and i could assume you are an expert on this subject.
Fine with your permission let me to grab your RSS feed to keep up to date with forthcoming post.
Thanks a million and please carry on the gratifying work. Xl 303
42 | Backend / Core | Bug Report | Very Low | Low | I am the new girl | Unconfirmed | |
Task Description
阴茎
43 | Backend / Core | Bug Report | Very Low | Low | Im happy I now registered | Unconfirmed | |
Task Description
outdoor sirens,external siren,outdoor siren with strobe,external siren with strobe,outdoor siren with light,outdoor sirens for security alarm,outdoor sirens Manufacturers,outdoor sirens supplier,external siren supplier,external siren manufacturersEstablished in 1998, DSW industry has specialized in manufacturing piezo sirens, electrical Sirens, outdoor Siren, emergency lighting, exit lights, strobe light, magnetic contacts, reed switches, smoke detectors and PIR sensors, motion sensors, control panels with ISO9000 in China for your house alarm system.
