Toaf mobile
TOAF Mobile for Android
IDCategoryTask TypePrioritySeverity  descSummaryStatusProgress
24Backend / CoreBug ReportVery LowHighDDE Read Errors incorrect dataAssigned
50%
Task Description
bad data reading in: temperature coolant, Rail Pressure, Injection Volume.
Test with engine running, 770 RPM, coolant 86 ° C, etc.
Log:
0100 - air mass meter
   Count : 40
   Error currently present
   Error not self-clearing
   Error on first occurrence with environment block 1 debounced saved.
   Error (for MIL) currently debounced entered.
   Error number : 1
   Engine RPM : 799.2 1/min
   Engine coolant temperature : -11.7 °C
   Injection volume : 0.0 mm^3
   Rail pressure : 0.0 bar
44Backend / CoreBug ReportVery LowHighafter car scan I get only DDE module line no othersUnconfirmed
0%
Task Description
First time I use Toaf on my RV75 year 2004 I got it running and communicate but car scan returns DDE/DME module info only no other one in the list
when clicking each modules either it says module not found/com error or shows the scroll bar and then displays a new page but info is missing. some wierd characters appear in some fields in low portion of the page
 17 Backend / CoreBug ReportVery LowMedium BCU Control Closed
100%
Task Description
Unlock doors in all options and rear windows rigth and left open/close errors. That’s not working
//mega.nz/file/1EYmmJhS#Z5IWgHhr70eGZvk8hwq_e00MqSJoSn_o302WUmB_JH4
18Backend / CoreFeature RequestVery LowMediumTranslate to SpanishUnconfirmed
0%
Task Description
no task description
 20 Backend / CoreBug ReportVery LowMedium DDE module control option not work Closed
100%
Task Description
//mega.nz/file/Rd52DCrQ#rqtFmDEyPQ0dP-FEn_l4UMx2XfkJIk_8BbczzC5MiUE
 21 Backend / CoreBug ReportVery LowMedium Restore BCU backup error Closed
100%
Task Description
Error: driver window does not close when restoring BCU from backup. returned to normal when restoring backup with toaf for windows
 25 Backend / CoreBug ReportVery LowMedium ABS Live data Closed
100%
Task Description
ABS live data log and live data chart not work. Always shows the value “0”
 2 Backend / CoreFeature RequestMediumLow Module support : Cruise Control V6 Closed
100%
Task Description
Add support to : Cruise Control module
 3 Backend / CoreFeature RequestMediumLow Module support : MEMS3 Closed
100%
Task Description
Add support : MEMS3 ECU - 1.8/1.8T Engine
 4 Backend / CoreFeature RequestMediumLow Module support : EMS2000 Closed
100%
Task Description
Add module : EMS2000 ECU - 2.0/2.5 V6 Engine.
 5 Backend / CoreFeature RequestMediumLow Module support : RS Closed
100%
Task Description
Add module : RS - Rain sensor ECU
 6 Backend / CoreFeature RequestMediumLow Module support : JATCO Closed
100%
Task Description
Add module : JATCO ECU - automatic gearbox.
 7 Backend / CoreFeature RequestMediumLow Module support : SMAC Closed
100%
Task Description
Add module : SMAC ECU - Seat memory and control
 8 Backend / CoreFeature RequestMediumLow Module support : SHD Closed
100%
Task Description
Add module : SHD - sunroof
 9 Backend / CoreFeature RequestMediumLow Module support : ATC Closed
100%
Task Description
Add module : ATC ECU - Automatic climate control
10Backend / CoreFeature RequestMediumLowModule support : WEBASTONew
0%
Task Description
Add module : WEBASTO - fuel buning heater.
11Backend / CoreFeature RequestLowLowFeature : fast actionsNew
90%
Task Description
Add feature : fast actions, like boot open, police headlight activation as button on app main window.
12Backend / CoreFeature RequestMediumLowFeature : parameters monitoringNew
70%
Task Description
Add feature : parameters monitoring like engine temperature, and show notification/alarm when value reach limit
 13 Backend / CoreFeature RequestMediumLow Module support : PDC Closed
100%
Task Description
Add module : PDC - park distance control.
14Backend / CoreFeature RequestMediumLowTranslation : PLNew
0%
Task Description
Add translation : polish Language
15Backend / CoreFeature RequestMediumLowModule support : BMNew
0%
Task Description
Module support : BM - board monitor
16Backend / CoreFeature RequestMediumLowModule support : CDCNew
0%
Task Description
Module support : CDC - CD Changer.
 19 Backend / CoreFeature RequestMediumLow ECU Backup Closed
100%
Task Description
Backup for modules stored in network.
 22 Backend / CoreBug ReportVery LowLow DDE Live data/ Start log error Closed
100%
Task Description
DDE Live data: error when selecting multiple options. Many options are repeated or similar so the app closes unexpectedly, there should be a warning sign before generating the crash
 23 Backend / CoreBug ReportVery LowLow DDE Live data/ Start log error Closed
100%
Task Description
26Backend / CoreBug ReportMediumLowWIFI InterfaceNew
90%
Task Description
Wifi interface for Toaf Mobile
 27 Backend / CoreBug ReportMediumLow DDE injectors Live data not working Closed
100%
Task Description
Live data for DDE injectors not working property
28Backend / CoreBug ReportVery LowLowJust want to say Hi!Unconfirmed
0%
Task Description
eyeglasses singapore,eyeglass frames,square eyeglass
framesAt HP-eyglasses, we understand that eyewear isn't just an accessory; it's an extension of your personality.
Our frames are designed not just to complement your features but to celebrate the distinctive beauty of Asian heritage.
With an unswerving dedication to excellence, we proudly extend our bespoke prescription eyeglass fitting service, honed over a decade of experience.
Your visual clarity is our priority, and we tailor prescription lenses to
harmonize with your individual needs.Elevate your eyewear experience to an art form.
Discover the intersection of trendsetting style and impeccable
functionality with our exquisite eyeglass frames. Your journey to eyewear excellence begins here.
29Backend / CoreBug ReportVery LowLowIm glad I now signed upUnconfirmed
0%
Task Description
glass bottle manufacturerDANYANG ENCHENG GLASS CO.,LTD.
,is the largest glass bottle manufacturing plant in Danyang, Jiangsu province, can design and produce any glass
containers/bottle from 2ml - 4,000ml in capacity and provide
the further processing treatment on . We
own three workshops and the daily productivity is 180 tons (200,000pcs
of 500ml bottles and 600,000 250ml bottles repectively).
Our products consist of various wine bottles, juice bottles, water cups, beer mug, candle jars, food jars
for honey, jam, picked food, salad and spice as well as Perfume bottles , diffuser lamp ,
liquid soap bottles and cosmetic jars. Besides, our plant can also provide the further
processing treatment on our prouducts including coating, frosting, printing and labeling.
We have both tin/aluminum cap workshop and plastic workshop for
our bottle products.
30Backend / CoreBug ReportVery LowLowJust wanted to say Hi.Unconfirmed
0%
Task Description
https://rpg999auto.com/ RPG999
31Backend / CoreBug ReportVery LowLowIm happy I finally registeredUnconfirmed
0%
Task Description
LTD. ,is the largest glass bottle manufacturing plant in Danyang, Jiangsu province, can design and
produce any glass containers/bottle from 2ml - 4,000ml
in capacity and provide the further processing treatment on .
We own three workshops and the daily productivity is 180 tons
(200,000pcs of 500ml bottles and 600,000 250ml bottles repectively).
Our products consist of various wine bottles, juice bottles, water cups, beer mug, candle jars, food jars for honey, jam, picked food, salad and spice as well as Perfume bottles
, diffuser lamp , liquid soap bottles and cosmetic
jars. Besides, our plant can also provide the further processing treatment on our prouducts including coating, frosting, printing and labeling.
We have both tin/aluminum cap workshop and plastic workshop for our bottle products.
32Backend / CoreBug ReportVery LowLowJust want to say Hello.Unconfirmed
0%
Task Description
MicroBulk Storage SystemsDSW is one of the leading manufacturers and exporters of high-pressure gascylinders and gas tanks
with industry-leading manufacturing ability that deliversunrivaled
gas cylinder stability. DSW enjoys a reputation as an industry leader inquality and
performance, which helps us sell industry gas tanks and Cryogenic Tanksworldwide.
33Backend / CoreBug ReportVery LowLowPlumbing Edwardsville IL Experts | Focused PlumbingUnconfirmed
0%
Task Description
Focused Plumbing
519 W Lake Dr
Edwardsville IL 62025
(618) 418-3102
Plumbing
34Backend / CoreBug ReportVery LowLowIm glad I now registeredUnconfirmed
0%
Task Description
Focus Lawns
1659 N Church
Belleville IL 62221
(618) 400-0930
lawn care belleville il
35Backend / CoreBug ReportVery LowLowIDSealUnconfirmed
0%
Task Description
IDSeal.net
2661 N Illinois St Suite 353A
Belleville, IL 62226
(618) 312-7605
idshield
36Backend / CoreBug ReportVery LowLowI am the new guyUnconfirmed
0%
Task Description
glufosinate herbicide label,glufosinate label,glufosinate ammonium label,glufosinate ammonium toxicityIn the world of contemporary agriculture,
the need for high-efficiency, low-toxicity,
and eco-friendly herbicides has never been higher. Jiangsu Agro Farm Chemical Co., Ltd.
stands at the leading edge of this agricultural revolution, devoted to the research study,
advancement, production, and sales of cutting-edge herbicides.
37Backend / CoreBug ReportVery LowLowIm glad I finally registeredUnconfirmed
0%
Task Description
obviously like your web-site however you have to check the spelling on quite a few of your posts.
A number of them are rife with spelling issues and I in finding it very troublesome to inform the reality however I'll certainly come back again.
Meriah 4d
38Backend / CoreBug ReportVery LowLowIm happy I finally signed upUnconfirmed
0%
Task Description
Uncover the universe of environmentally friendly energy in the bevverage industry.
Comprehend how precisely forefront companies are leveraging hydro energy for craft preferred
beveraes whilst reducing thhe carbon footprint.
Keepp enlightened via our detailed write-ups, real-world examples,and insightful
resources. Be a member oof our revolution toward a more eco-consciousplanet
with our platform.
GreenBeverageProduction
39Backend / CoreBug ReportVery LowLowIm happy I finally registeredUnconfirmed
0%
Task Description
Liquid nitrogen dewar,cryogenic nitrogen dewars,cryogenic nitrogen tank,cro storage dewars,nitrogen dewar
flask,cryogenic dewar supplier,china liquid nitrogen dewar,cryo dewar
manufacturerDSW is one of the leading manufacturers and exporters ofhigh-pressure gas cylinders, cryogenic tanks, and gas tankswith industry-leading manufacturing ability that deliversunrivaled gas cylinder stability.
DSW enjoys a reputation asan industry leader in quality and performance, which helpsus to sell industry gas
tanks and Cryogenic Tanks all over theworld.
40Backend / CoreBug ReportVery LowLowI am the new guyUnconfirmed
0%
Task Description
Worman Law LLC
222 S Meramec Avee Suite 203
St. Louis MO 63105
(314) 695-9529
dog bite lawyer st louis
41Backend / CoreBug ReportVery LowLowIm glad I now signed upUnconfirmed
0%
Task Description
Just wish to say your article is as astounding.
The clearness in your post is simply spectacular and i could assume you are an expert on this subject.
Fine with your permission let me to grab your RSS feed to keep up to date with forthcoming post.
Thanks a million and please carry on the gratifying
work.
Xl 303
42Backend / CoreBug ReportVery LowLowI am the new girlUnconfirmed
0%
Task Description
阴茎
43Backend / CoreBug ReportVery LowLowIm happy I now registeredUnconfirmed
0%
Task Description
outdoor sirens,external siren,outdoor siren with strobe,external siren with strobe,outdoor
siren with light,outdoor sirens for security alarm,outdoor sirens Manufacturers,outdoor sirens supplier,external
siren supplier,external siren manufacturersEstablished in 1998, DSW
industry has specialized in manufacturing piezo sirens, electrical Sirens, outdoor Siren, emergency lighting, exit lights, strobe
light, magnetic contacts, reed switches, smoke detectors and PIR sensors, motion sensors,
control panels with ISO9000 in China for your house alarm system.
Showing tasks 1 - 43 of 43 Page 1 of 1
Available keyboard shortcuts
Tasklist
Task Details
Task Editing
